Vauxhall XE Trigger Wheel fitment questions
retrocarclub
Post by retrocarclub »
I'm currently attempting to fit MJ Lite to my c20xe engine but i'm having trouble working out how to mount my 36-1 trigger wheel to my front pulley. I've read the guides on this site, but they don't really help because I cant weld it or bolt it on! Somebody please help.
Cheers
Christian
-Ad-
Post by -Ad- »
Knowing a c20xe bottom pully, it looks easy to bolt it on in my opinion.
Just use the small 6 bolts that hold the pully to the main crank pully/sprocket.
________
Michigan medical marijuana dispensaries
retrocarclub
Ok, thanks I didn't really consider using the smaller bolts for some reason. Would you shim them out to the level of the trigger wheel?
MartinM
Post by MartinM »
retrocarclub
Thanks Martin, that's a lovely setup. Did you machine down the pulley and bolt the trigger wheel on or did you weld it? Also what size trigger wheel did you use? I'm looking at a 6.5" trigger-wheel.com one.
MartinM
Post by MartinM »
Unfortunately I only did the MJLJ side and it's not mine - I'll try and find out....
retrocarclub
MartinM wrote:Unfortunately I only did the MJLJ side and it's not mine - I'll try and find out....
Ok thanks mate.
retrocarclub
Did you have any luck?
MartinM
Post by MartinM »
Oops - forgot :oops:
Will try to find out this weekend....
