1380 mini maps?
Post 1380 mini maps?
Anyone got a map for a 1380 NA mini? need a staring block to work from, so any 1275+ ebgine map should do (as long as CAM isnt above say 276)
Any help appreciated.
Ross.
Here's my current map,
A+ Series 1275cc (modified up to 1380cc)
MED engine, bored to 73.5mm with Omega pistons,
276 Kent cam,
lightened flywheel,
Stage 3 head with 36mm Inlet & 31mm Exhaust Valves.
Weber DCOE 45 carburetor
own.mjlj
 Description:
Download
 Filename:  own.mjlj
 Filesize:  717 Bytes
 Downloaded:  897 Time(s)
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Hi, Many thanks for that, similar spec to mine... has your car been on a rolling road?
Cheers
Ross.
HI ken555
can you make a MAP to my engine? and upload to my post "Testing MJLJ->A-series 1380cc"
-New HIF44 BDL
-Inlet manifold minispares
-1380cc 73.5
-Stage 3 36-30 ported + chamber
-LCB millenium & RC40
-STD rockers (future swiftune 1.5 high lift)
-Swiftune 5 (future Swiftune 10)
-K&N filter
-11:1 CR
-Front radiator
-Lightened flywheel aeg-619
I watching your configuration MAP of your engine, why you start with 24ºand then drops to 8º?
Can you explain a little more the map for your engine.
sorry my english.
I would use this map as a starting point.
To prevent the car from stalling (stopping) when it is cold or first started, when the revs drop to 800rpm, it get quite a bit of advance that puts the revs back up a bit.
No not yet, a few more things to be done first.
thanks i test your config in to my engine.
