Is my trigger wheel secure?
Yvan
Post by Yvan »
I have finished installation of my MJLJ setup, and it all runs OK, but I have one question.
On the photo below, you can see how I secured trigger wheel to the pulley. I drilled three (120 degrees apart) holes in ~2mm thick pulley, tapped three M3 threads into the trigger wheel, and used M3 bolts to connect it together. I used some compound that prevents bolts to become loose, and I plan to change the bolts, to use longer ones, so I can put a nut on the inner side as another safety measure.
Trigger wheel is light, and all looks quite secure, but what do you think?
Trigger wheel connection to the pulley
TriggerWheel
TriggerWheel
'87 BMW 316 E30
1600cc M10B16
petrol + LPG, MJLJ
Hi Yvan,
That design should be adequate- but through previous experience I found that a permanent attachment is best. This is what we currently have on our toyota 4AG motor:
A bigger concern is the sensor bracket- it may need bracing. If you have any mis-firings around 3500-4500 rpm, the bracket may be vibrating. Also, check for strike marks/rubbing on the sensor face and the wheel.
Yvan
Post by Yvan »
I do most of my driving below 3500 rpm (slow city driving), but I did test my setup at higher rpm, no problems so far.
Bracket is made out of 15x15 mm RHS (rectangular hollow steel) ~2mm thick. Perhaps I could fix it to the alternator bracket, or somewhere else, I'll think about it. Thank you for the suggestion.
'87 BMW 316 E30
1600cc M10B16
petrol + LPG, MJLJ
I forgot to add the picture of our trigger wheel:
One thing you may consider is adding a extra bolts to secure the wheel, otherwise it seems 'OK'.
Regards
Yvan
Post by Yvan »
It looks heavy, mine is thin one, it looks like it is not used as dampener, just serves as a pulley.
'87 BMW 316 E30
1600cc M10B16
petrol + LPG, MJLJ
