I am trying to upgrade my megajolt fron V3 to V3.2.1. I have saved the file to my pc and am following the instructions as follows
Open a command window (Click Start / Run, and enter 'cmd') and then navigate to the directory where you downloaded your MJLJ files.
My cursor sais c:\documents and settings\adam howard>.
I have typed in the following after the prompt 'c:\documents and settings\adam howard\my documents\megajolt' but get a message saying c:\ is not recognised as an internal or external command, operable program or batch file.
How can i navigate to the relevant file so that i can enter the > hc08sprg.exe COM1 mjlJunior_V3.2.1.s19 command
Sorry that it may sound a daft question but I am not that good with computers
Firmware upgrade problem
philhoward
- Contact:
Phil Howard
philhoward
- Contact:
philhoward
- Contact:
philhoward
- Contact:
The following files are listed
09/05/2008 16:15 <DIR> .
09/05/2008 16:15 <DIR> ..
09/05/2008 16:14 723 data 9-5-8.mjlj
09/04/2008 19:58 1,987,652 mjljConfig_v3.2.1.exe
09/05/2008 16:15 7,850 mjlJunior_V3.2.1.s19
3 File(s) 1,996,225 bytes
2 Dir(s) 28,315,385,856 bytes free
When I saved the controller firmware I right clicked and saved target as, as I did not have an option for save. Would this be the problem
Phil Howard
philhoward
- Contact:
I have just realised that i did not download the Firmware programming software. I have now done this and it accepts the command hc08sprg.exe ......
It is now just counting on calibration break pulse. count ...
it has got to over 1000 so I have disconnected the power
Any ideas what to do now?
Phil Howard
philhoward
- Contact:
