Firmware version
Firmware version
How do I interrogate MJLJ to determine the version of firmware It's currently running?
What configuration software version are you running? If you're running 3.0.x then you likely have the 3.0.x firmware. If you're running 3.2.x config software then likely you're running the latest firmware. The 3.2.x software fetches the version number from the controller- click "Help/About" and it will show you the version.
