I understand that the basic principle is to put the car on the rolling road, check the torque and power output for each RPM entry in the configuration software (1000, 2000..., your granulation may vary
Is this correct, and what is the typical setup, rolling road operator handles everything or just tells me the roads result for each RPM entry
and i tune the map? Also, how does the MAP sensor come in, how would that be set up in the 3D map?
