The right EDIS coil pack wiring? (uber simple picture)
paulc
Post by paulc »
Looking for a Yes / No. I searched Google, here, megasquirt forums and couldnt find anything as simple as this - so i made it.
edit: see below for picture.
Patriq
Post by Patriq »
Not an answer to your question about the plug.
But what you have incircled as coil A - that should be cylinder 1&4, not 1&3. Since either cyl 2 or 3 fire after cyl 1 on a 4cyl engine.
Shouldn't it ?
snapperpaul
Post by snapperpaul »
The coil pack annotations are correct, its a coil pack not a distributor.
A coil pack like this is effectively 2 coils that fire from both ends so when a spark is sent through plug lead to cylinder 1 a wasted spark also goes to plug 3, coil packs usually pair odd and even cylinders together hence 1 + 3 and 2 + 4
Patriq
Post by Patriq »
snapperpaul wrote:The coil pack annotations are correct, its a coil pack not a distributor.
Yes, I know that. But at least in my installation - cyl1 and cyl 4 fire together with a wasted spark on cyl 4 when cyl 1 ignites - and same with cyl 2 & cyl 3.
Ken555
Look right to me
Post by Ken555 »
Seems the same as I had mine wired to start with, before fitting the Rev-limit module.
Only thing I did was move the earths/shields to seperate pins, they are all common inside the EDIS unit.
My simple diagram (modified from one on here)
alexander
but....
Post by alexander »
............ patriq is right about the coil labelling being incorrect. one coil fires 1&4, and the other fires 2&3. the above diagram incorrectly says otherwise.
alexander.
paulc
Post by paulc »
edit: pic removed
DannyP
Post by DannyP »
It all depends on the firing order of your engine. Mine is 1-4-3-2, so 1 & 3 are together, as well as 2 & 4. Most inline 4s are 1-3-4-2, so check before you wire it up.
paulc
Post by paulc »
mine is also 1-4-3-2 (VW Type 4)
So, that means that 1 and 3 should fire together and 2 and 4 should fire together? (for this application)
alexander
Post by alexander »
paulc wrote:mine is also 1-4-3-2 (VW Type 4)
sorry paul, you are correct. i have not come across a motor with that firing order - just my lack of wide experience i guess - and had neglected that possibility.
regards
alexander.
