error in Installation Guide EDIS plug diagram
alexander
Post by alexander »
hi brent, et al,
maybe this has been discussed before, but i have noticed that the graphic in the Installation Guide, which shows the wiring setup for the EDIS plugs, has some errors. specifically, the locating tabs on the plugs are not correct. the graphic shows them as the same profile on each of the EDIS4, 6 and 8 plugs, whereas these plugs are all slightly different from each other.
compare the graphic, with this:
http://www.extraefi.co.uk/drawings.htm
i am currently installing an EDIS8, having previously installed an EDIS4. on the link above, you will see that the EDIS8 plug has a centrally aligned locating tab at the 'top' ie next to the PIP wire, and one offset to the left at the bottom. that matches the plug i have. the graphic in the Installation Guide shows the plug shaped differently. similarly, the EDIS4 plugs are different to the installation guide.
yes, the wires are shown correctly in relation to the clip on the plug, in each case, but it would be better if the graphic really did match this important and unique feature of the respective plugs.
regards
alexander.
Thank you for bringing that to our attention. We'll get any errors fixed asap!
