My instructions say VR sensor connected to pin 5 and 6...But also, TPS pin 6 (on the EDIS).....is this correct???????????????.........Or am I losing the plot....
Sanity check....
TPS is connecting to
TPS is connecting to Megajolt!
Here is what you do, leave the Megajolt and TPS out of equation. Work with these for now: VR, trigger wheel, EDIS, coil packs, and the wiring that goes between them. It will be enough to provide constant 10 BTDC timing when installed properly. After you have it wired try to fire it up, if not working swap wires from pin 6 to pin 5 and from pin 5 to pin 6 (VR sensor).
Of course!!!!.....
So, I can confirm I did loose the plot
Thanks.....
OK, will hopefullly try the first run this weekend and see if I get my 10' timing.....
Many thanks.
Thanks.....
Many thanks.
