Mini A series Track Car in Australia
jspink
Post by jspink »
Hi, thanks to you all!
(click on the blue hyperlinks for images)
I'm up and running in Australia with a .
<a href="http://218.214.145.103/zspink/engine_bay.jpg">1310cc A series with 45mm DCOE Weber in a '63 shell </a> Edis-4, coil pack and vr sensor from Chris in the UK, PCB, chip, mapp sensor and molex from Brent, box and other components locally. Mounted Megajolt on <a href="http://218.214.145.103:80/zspink/megajo ... >passenger glove tray. </a> I had trigger wheel , bolted onto (not the rubber mounted harmonic balancer) and then bent over the teeth. <a href="http://218.214.145.103:80/zspink/trigge ... jpg">laser cut from 3mm steel </a><a href="http://218.214.145.103:80/zspink/no_sen ... pg">engine pulley </a>Made a bracket to mount the VR sensor from the side engine mount bracket. Mounted the EDIS up above fuse box on firewall and <a href="http://218.214.145.103:80/zspink/coil_p ... .jpg">coil pack over unused heater-hose-hole panel. </a> Got the made up here by "The Lead Man" in Melbourne, $60 for 4 x HT leads and 3 x cable management clips in 8mm Top Gun spiral cable. <a href= "http://218.214.145.103:80/zspink/ht_coi ... on.jpg">HT spark plug leads </a>Generated my own base map from other mini maps here on the downloads page and from initial testing. Initial problems were: bad earth connection meant EDIS no work, also I wired the coil input wires backwards - just swapped the spark plug HT cables back to front and all systems go!
Julian Spink
