(Originally posted by flashrs1988)
Engine Mfg: Ford
Engine Code: 1600
Cylinders: 4
Displacement: 1600
Rev Limit: ??
TPS or MAP: MAP
Boosted or Normally Aspirated: Boosted
If Boosted- max Pressure (KPa): 175
Modifications: Cam, exhaust, intercooler
Chassis: ??
Notes:This is the current map I have been using for some time now and has been running fine, the engine is more or less standard, e.g. turbo, intercooler, cam, exhaust. But is running a K+N panel filter and -31 actuator. The boost has been raised from the standard 6-7 psi to now run 10-11 psi, I would point out that you are now on the very limit of the standard intercooler unless you live in a very, very cold country.
The map config has been set by trial and error. I would not say it’s 100% correct but would be a good starting point to get you up and running…..
Ford 1600 RS Turbo, Standard Engine, Intercooler
- v9rst1barmap.mjlj
- (801 Bytes) Downloaded 1468 times
