Reply to topic Page 1 of 1
Vauxhall C20xe w/carbs
Post Vauxhall C20xe w/carbs
(Originally posted by fodderboy)
Engine Mfg: vauxhall
Engine Code: c20xe
Cylinders: 4
Displacement (cc): ??
Rev Limit: ??
TPS or MAP: MAP
Boosted or Normally Aspirated: Normally Aspirated
If Boosted- max Pressure (KPa):
Modifications: Carbs
Chassis: ??
Notes: "here is a basic map for the vauxhall c20xe running on carbs
this map is a slightly alterd version of pioneerx's vauxhall 1.8 8v map im running this map with the newest firmware version"
vaux-opel c20xe base map.mjlj
 Description:
Download
 Filename:  vaux-opel c20xe base map.mjlj
 Filesize:  794 Bytes
 Downloaded:  2014 Time(s)
Post
There's an updated version of this map here, after rolling road setup:
http://www.autosportlabs.org/viewtopic.php?p=18846
