Reply to topic Page 1 of 1
Default map for standard Pinto Engines
Post Default map for standard Pinto Engines
(Originally posted by KITT)
Engine Mfg: Ford
Engine Code: Pinto
Cylinders: 4
Displacement (cc): Unknown
Rev Limit: Unknown
TPS or MAP: Unknown
Boosted or Normally Aspirated: Normally Aspirated
If Boosted- max Pressure (KPa):
Modifications: Unknown
Chassis: Unknown
Notes: "Default map for std. Pinto engines. Also link to my website with loads more maps."
Pinto 3D base 6k.mjlj
 Description:
Download
 Filename:  Pinto 3D base 6k.mjlj
 Filesize:  798 Bytes
 Downloaded:  1459 Time(s)
Post MAPS for Ford DOHC 8V (Europe)
Hi, i'm from France and I just buy MEGAJOLT MAP version....... i'll with to have a MAPS for Ford DOHC Engine from 1990 Twin Cam if possible....
Thanks regards.
Mario DANTAS
France
_________________
SIERRA 2.0 DOHC 8V or 16V + Ford EDIS4 + Mejajolt = Happyness.........
View user's profile Send private message Visit poster's website MSN Messenger
Post re: pinto map
Hi all,
Just wondered why on the default map the rev limit is set to 2000 rpm. SHould this not be 6000 or 6500.
thanks
alex
Post
Is this a amercian or europian pinto engine?
