EDIS Interchange
Paratime
EDIS Interchange
Post by Paratime »
I have compiled a list of cars that use the same Standard Ignition after market replacement modules and coils. I can't say that all modules will work with the MJLJ, but if you know of a car that does, others in its group should too... Confirm that the module is labeled EDIS 4 6 or 8.
4 cyl. and 8 cyl coil packs are the same (8 uses two)
Standard Ignition FD-487
98-99 Escort 2.0 8 valve
97 Escort 2.0
91-97 Escort 1.9
91-93 Mustang 2.3
96-98 Mustang 4.6
92-97 Crown Victoria 4.6
94-97 Thunderbird 4.6
89-98 Ranger 2.3
91-98 Town Car 4.6
95-97 Continental 4.6
93-96 Mark VIII 4.6
97-99 Tracer 2.0 8 Valve
91-96 Tracer 1.9
91-98 Grand Marquis 4.6
94-97 Cougar 4.6
4 cyl. modules
Use Standard Ignition LX-239
91-97 Escort 1.9
91-96 Tracer 1.9
Use Standard Ignition LX-253... looks similar, may or may not work
95-99 Escort & Contour 2.0
95-99 Mystique 2.0
6 cyl
Coils:
Use Standard Ignition FD-488
96-00 Taurus 3.0 DOHC
95-99 Contour 2.5
95-99 Mustang 3.8
94-97 Tbird SC 3.8 (some years CA only)
95-96 Taurus 3.0 FFV & Tbird CA
95-96 Windstar 3.0 & 3.8
96-99 Sable 3.0
94-97 Cougar 3.8 CA
95-98 Mystique 2.5
Use Standard Ignition FD-480
89-95 Taurus SHO 3.2
90-97 Ranger 4.0
90-96 Aerostar 4.0
91-96 Explorer 4.0
Use Standard Ignition FD-490
93-95 Taurus SHO 3.2 MT
Use Standard Ignition FD-482
89-93 Tbird SC 3.8
* 6 cyl coil packs appear to differ only in the angle of the connector mounting
6 cyl Modules
Use Standard Ignition LX-676
95-99 Contour 2.5
95-98 Mystique 2.5
Use Standard Ignition LX-256
95-99 Mustang 3.8
94-96 Tbird SC 3.8
94 Tbird 3.8 CA
94-97 Cougar 3.8 CA
Use Standard Ignition LX-254
95 Windstar 3.0 & 3.8
94-95 Aerostar 4.0
94-95 Explorer, Ranger 4.0
Use Standard Ignition LX-238
91-93 Explorer 4.0
90-93 Aerostar, Ranger 4.0
*Most 6 cyl DIS cars use a two connector module. probably not EDIS compatible...
8 cyl modules:
Use Standard Ignition LX-243
99-00 Mustang 4.6 (96-98 Mustang 4.6 do not list a module)
92-97 Crown Victoria 4.6 (some 92 C.V. 4.6 use LX-251)
94-97 Tbird 4.6
92-99 Town Car 4.6 (Some 91-92 use LX-251)
91-98 Grand Marquis 4.6 (Some 91-92 use LX-251)
94-97 Cougar 4.6
Use Standard Ignition LX-248
93-96 Mark VIII
Crank sensor wheels
Great information, thanks!
Any information out there on different crank sensor wheels? I know of two- the one off of the 1.9L ford escort, and the 5.0L mustang motor (year ??).
The mustang version is smaller than the ford escort, but comes seperately from the crank pulley- the ford escort version requires the pulley to seperated from the sensor wheel.
