vacuum reservoiur
fikus01
vacuum reservoiur
Post by fikus01 »
sorry for bad spelling, remember recently a thread about using the vacuum readings from webber carb fitted engines or those with lumpy cams, i said that rover fitted a ball to act as a reservoire for map readings on the exige because of fitting the engines with throttle bodies. well i stumbled across the pictures again
the specific one i remembered was - http://bookatrack.com/-PG?uldis&2326&19029&640&.jpg
but generally his whole car looks good if you're bored and like lotus's - http://bookatrack.com/-pg?2326&19029
enjoy.
