Ford TFI support
Mechcano
Ford TFI support
Post by Mechcano »
Would support for the Ford TFI distributor be possible (not the signature PIP distributor), as the PIP signal is already present. Can the existing code be modified to provide a SPOUT output instead of SAW and released as TFI only firmware. This may be a step backwards in technology, but there would be many a points and magnetic pickup dizzy begging to be replaced by a TFI unit and the advance curve controlled by the MJLJ stand alone system.
Micheal
________
WIKI VAPORIZER
Hi Micheal,
That is a very interesting idea. If you'd like to do some research on the specification for the SPOUT signal and document it in the wiki, that would be fantastic.
Someone could take on modifying the firmware, or I can put it on my to-do list.
Thanks for the thoughts!
