V2 Outputs not working
greypride
Post by greypride »
Hello, I hope ive got this in the right section
Unfortunatetly whilst trying to put a brighter shiftlight in my car (using a relay) i managed to kill all of my switchable outlets on the megajolt.
Im using the V2 board so it has the transistors instead of the chip of the V3, im thinking I couldnt have blown all 5 at once (i tested using the multimeter), so is there something before or after them.
Any assistance will be much appriciated
Cheers
nic
greypride
Post by greypride »
Boo hoo Anyone??
Sorry we neglected you!!
You're right, it is unlikely you blew all of your outputs at once- unless the whole MJLJ died in the process. I'm assuming it's still working, adjusting the ignition timing and communicating with the configuration software?
How are you testing that your outputs are working? What are you setting in the configuration software, and what are you using to detect the outputs activating? A simple LED circuit as illustrated in the assembly guide would be a good starting point.
