VW 1500 Squareback with Megajolt
knastenrad
Post by knastenrad »
HI
some pic's of my -66 VW squareback with the great Megajolt box :)
2,2Watercooled Vanagon Boxer with turbo, Water/air IC,Megasquirt/Megajolt
That is a simply gorgeous machine and a super clean engine layout, and turbocharged to boot! Thank you very much for sharing!
knastenrad
Thx! glad u like it :)
dr.occa
Post by dr.occa »
wow, very clean engine bay. pristine looking car. great job on it!
Gilesy998
Post by Gilesy998 »
Taht is one seriously pretty ol' dub 8) Is there anything we should know about the front grille? Never seen a T3 with a grille before :lol:
DannyP
Post by DannyP »
I like it! You've got guts turboing a wasserleaker, dude. I hope you have spares! :lol:
How much boost are you running?
I have 91 Westy, pondering selling it.
Also have a type1 powered 550 Spyder, Megajolt to be installed this winter. System is ready to go, just have to pull the motor to mount the trigger wheel as it is mid-engine. No room to work between the pulley and the firewall.
knastenrad
thx guy's. :)
Those leakey WBX are actually very nice and strong engines if you sort out the "small" issues regarding leaking.
Crank and case are bulletproof. great for turbo/torque.
I have experimented with turbo on a couple of other WBX engines , in a beetle i had. and the can handle a descent amount of boost.
Now i run 15PSI but had i up in 21PSI . (wastegate issue :) )
The grille is from a Superbeetle decklid... got to have some air to the radiator if front.
I try to use VW parts as long as it is practical.
knastenrad
got some dyno result now after doing the map's my self.
pretty happy with the result. :)
260HP and 356NM of torque.
a lot thx to MEgajolt! :D
paulc
Post by paulc »
care to share your MAP?
toomanyveedubs
Post by toomanyveedubs »
can you tell me more about your turbo setup?
tia
BRUCEROE
VW
Post by BRUCEROE »
Very impressive work. I suppose you have some sort of fuel injection? Bruce Roe
