Triumph Spitfire 1500 1976
mikaking
Post by mikaking »
Engine Mfg: Triumph
Engine Code: FM
Cylinders: 4
Displacement (cc): 1500
Rev Limit: 6000 (ish)
TPS or MAP: MAP
Boosted or Normally Aspirated: NA
If Boosted- max Pressure (KPa):
Modifications: S/S 4-2-1 Downpipe to custom rear pipe and box, Twin 40 Dellorto's, Mechanical pump assembly removed, Electric Fan and Electric Water pump
Notes: The default Map worked fine but seemed to lack in top end power and splutter a bit on high load low revs, the new map seeds to have ironed these probs out. Maybe the 600rpm column could do with some work.
Spitfire1.mjlj
(689 Bytes) Downloaded 1456 times
