Switching config resets maps
Ken555
Post by Ken555 »
Using a Version 2 board, with firmware version 2.8.0 and PC Configuration/Tuning software, version 3.2.1
I load up 2 different maps, click on open file, click on write ignition configuration.
Then flick switch, and repeat for 2nd map.
When I return to map 1, it has reset to the factory defaults, flick switch again and map 2 has reset.
Any ideas ?
Ken555
Re: Switching config resets maps
Post by Ken555 »
Ken555 wrote:Using a Version 2 board, with firmware version 2.8.0 and PC Configuration/Tuning software, version 3.2.1
Any ideas ?
Ignore me, I'm an idiot. :roll:
Guess who forgot to write the setting to Flash :oops:
Well, it's certainly not 100% obvious either! Soon to be properly documented.
Glad you figured it out!
themaninthesuitcase
Post by themaninthesuitcase »
I did the exact same! The docs are much needed!
