Mega Jolt compatibality with Logworks
merlin
Post by merlin »
Hi I have just baught the G3 A/F ratio gauge and LC-1 from Innovate Motorsports is there any compatability between the Mega jolt and the LC-1 for data loging.
Merlin
What things would you like to log?
The MJLJ doesn't have any dedicated logging outputs. However, depending on the logging hardware you have, certain things may be possible.
Ignition advance- If the logging system can measure pulse-widths, you extract the ignition advance by having it measure the SAW pulse.
MAP reading- you can probably modify the MJLJ board to bring out the MAP sensor voltage output to an unused pin on the connector; or, if you have TPS you could read the TPS sense line.
RPM - the logger should have this in-built.
Anything I missed?
merlin
Post by merlin »
Thanks brent,
that is spot on RPM and MAP is realy all I want I think that LogWorks trough the LC-1 uses voltage as it trighers so not sure how to get RPM in trought this
wha mods do you recon i would need to make to the board to get a map voltage out.
Thanks for all your help.
