Should I use the standard diameter vacuum pipe (1/8" inside dia), or should it be larger or smaller? Is there any benefit in restricting the flow?
Would the length of connecting pipe make a difference? I'm thinking of fixing the reservoir just above the manifold, so each of the pipes would only be a few inches in length.
I had thought of mounting a suitable tube directly onto the runners, with restrictors between the runners and the tube, but I'm not sure how practical that would be - it would certainly be difficult to fix if it didn't work first time.
cheers,
David
P.S. I'll finish this carb upgrade one day...
