zetec 1.8 gsxr 1000 carbs
fozzie
Post by fozzie »
Hi there all,
Does anybody have a map for this concockion
It would help me out a bit. i've not started it yet.
Also does anyone know what size i need to drill the jets out i was told 0.6mm
regards Fozzie
FazerBob
Zetec
Post by FazerBob »
Hi Fozzie, I'm running an 1800 Zetec on Fazer 600 carbs, with the jets drilled out to 1.6mm. This seems to be about the right size as mine runs fine - except for the engine being smoother with 23 degrees of advance at idle, rather than the expected 10-12 degrees.
