Megajolt and knock sens
frans
Post by frans »
Would it be possible when you have a turbo engine blowing through a carburettor to mount a knock sensor and some how hook it up to the option switch. If you then load 2 advance curves, the 1 trailing the other by about 3 or 4 degrees and you drive the car on option 1. If you then at some point detect a knock the sensor then switch the option switch and it then fails over to the trailing curve that will then retard the timing by the 3 to 4 degrees.
If this can be done the Megajolt will effectively save engine from detonation.
Any comments?
Regards
Frans
Hi, this was actually discussed some time back. you might find the previous thread useful:
http://www.autosportlabs.org/viewtopic. ... knock#6134
