tps over map
rich
tps over map
Post by rich »
hi ,
been trying to suss out this system over the last two days and have been told tps is better than map with a wilder cam .
can some one tell me the advantages , the way i see it is that the map system creats lulls and highs where you dont need them but the tps knows exacty what your doing.
am i right
i have a dolly sprint with lairy cam and dellorto 45's.
this kind of stuff the germans were just developing :D
MartinM
Post by MartinM »
http://www.autosportlabs.net/Choosing_b ... MAP_or_TPS
...explains it all pretty succinctly.
With twin 45's, I'd suggest a TPS unless you're into doing a lot of pipework...
alexander
Post by alexander »
of course some wiseguy always comes in with a different opinion... :)
i have a 1565cc renault R16 motor with twin weber DCOEs. i drilled a hole in each runner, tapped in a piece of brass tube, made a small plenum out of brass sheet, ran vac hose from the 4 runners to the plenum. one tube out to the MJ sees dead steady vacuum. the cam is stock, but my hunch is that no matter how wild your cam, i wouldnt think it would introduce enough pulsation to upset this arrangement (on account of the motor being, what?, 2litre?).
it may well be that a TPS is easier to fit, and a better solution for that reason, but my feeling is that MAP option is still completely viable. i bent and soldered the plenum, but you could just as easily glue the tubes into any small tin or plastic box eg an abs electronics hobby box for instance.
regards
alexander.
tubes in manifold 4 - small.jpg (56.08 KiB) Viewed 5545 times
