Mini wont start - backfiring
ZeroT
Post by ZeroT »
I have finally had the time to install my MJ and got it all fitted this afternoon to my mini, MG 1275 standard angine.
First I fitted the crank sensor and started the car on the coil and dizzy and the laptop read back the rpm.
I then removed the dizzy and coil and fitted the rest of the EDIS4 setup.
The MJ has the default map on it.
Turned the key and after a few turns, bang! a loud back fire from the exhaust.
Tried a few more times and I get a mixture of bangs from the exhaust and backfires back thru the carb too but no chance of the engine starting.
Suggestions please!
Ken555
Post by Ken555 »
Sounds like the timing is miles out.
where did you fit the toothed wheel / sensor.
Remember the gap should pass the sensor 90 degrees before Top Dead Centre.
Also, ensure you have the coil pack firing order correct.
ZeroT
Post by ZeroT »
I have connected coil pack number 1 to spark number 1, far right of mini engine.
And then the coil pack numbers 2, 3, 4 to sparks 2 3 4 numbering from the right.
ZeroT
Post by ZeroT »
ok, resolved, looks like coils A & B were firing the wrong way round :oops:
Don't worry, a couple of weeks ago I was in a rush connecting wires and experienced the same exact thing. :)
charlie
Post by charlie »
Me too. Exact same thing.
