Hi I've just been given a ford esc ignition control box.
It has a vacuum take off going straight into the control unit.
Is this unit suitable for use with MJLJ?
I'm guessing not.
Varnish
Ford ESC
capri_turbo
standard ford map sensors use a similar freescale unit to that of the MJLJ, BUT it is the non ported type and is sealed in the ford unit. There is also a PIC in there which must do the conversion to a frequency.KLAS wrote:don't think so, Ford map sensors normally produce a frequency not a voltageDannyP wrote:You might be able to open it up and salvage the MAP sensor though.
