New for Spring 08!
New for Spring 08!
Here are some new things we've been working on this spring.
MJLJ V4
What started as a necessary migration to a new microcontroller ended up with just- ahem- a 'few more' changes- so now we're testing new firmware and a new board design.
Read more:
http://www.autosportlabs.org/viewtopic.php?t=1718
Hard Rev Limiter production
We did a minor update to the hard rev limiter in advance of production. We adjusted the board size to fit V3 and V4 cases, and added in pads for a through-hole transistor, since the SOT-23 transistor is just too tiny and annoying to hand mount.
More:
http://www.autosportlabs.org/viewtopic.php?p=7964
Lighting
Need something to do with those user-defined outputs? Here are a couple of choices- one is a dual LED cluster, the other a 5 stage sequential shift light which will use up all of your outputs.
The dual LED cluster comprises a ring of ultra-bright blue LEDs, with an inner ring of red. The LEDs overloading the camera's sensor, so it was a bit hard taking a picture of them while illuminated.
The 5 stage cluster will combine ultra-bright green, yellow and red LEDs. Pictures forthcoming!
luke6040
Post by luke6040 »
when are those cool shiftlights gonna be on sale i want some lol.
As soon as we get the flat rate shipping working in the store!
Here are a couple of pictures of the sequential array- if you don't have a use for your outputs this could be a fun addition.
luke6040
Post by luke6040 »
what size are they i need summat to fit these bhind the silver bits. in this pic. http://i73.photobucket.com/albums/i229/ ... _A0211.jpg
Salamander
Post by Salamander »
Beautiful +1
luke6040
Post by luke6040 »
luke6040 wrote:what size are they i need summat to fit these bhind the silver bits. in this pic. http://i73.photobucket.com/albums/i229/ ... _A0211.jpg
BUMP on size
About 1.1 x 1.2" square on the dual LED cluster.
These should be up in our store as we've finally figured out the Priority mail flat rate envelope. $11 USD shipping with tracking!
luke6040
Post by luke6040 »
thanks for the reply. i meant the whole thing though.
Glad to hear you got it sorted, ill be buyin some more stoof soon then
Arwendur
MJLJ V4
Post by Arwendur »
Hi there,
When is V4 availbale for purchase?
Steve
Hello Steve,
It will be available soon- and worth waiting the short time for. I will post an update with firm dates later today.
Update:
Our target availability date is May 23!
with pricing identical to V3, and is now available for pre-ordering in our store.
