TPS Calibration
Arnie
TPS Calibration
Post by Arnie »
Finally installed megajolt into my MK Indy running a 2lt Pinto with bike carbs. Seems to be running okay after adjusting the VR snesor. However running with a TPS and on the configurator it shows on TPS gauge 75% on idle going to just over 80% on full throttle. Is there a way of calibationg the TPS. Running V3.0.0 software. Any help would be much appreciated.
Reagrds,
Arnie
Hi Arnie,
To do proper TPS calibration you will need to upgrade the firmware to 3.2.1 and use the 3.2.1 configuration software. The firmware upgrade guide is in our wiki (how to) section of the website.
Arnie
Post by Arnie »
Brent,
Thanks for the update will give it a go and see how I get on. Once agin thanks for your help much appreciated.
Arnie.
