Triumph Spitfire 1300. Performance starter map.
bobyspit
Post by bobyspit »
Here is my starter map for the Triumph Spitfire 1300 MKIV.
Large crank.
Lightened and balanced Crank.
gas flowed head.
Fast road cam.
Twin HS4's carbs running AAA needles.
Roller rockers.
91 BHP at the wheels.
Any Q's just ask.
Rob
Robbaiscmap.mjlj
(719 Bytes) Downloaded 2032 times
bobyspit
Post by bobyspit »
My updated map from above but tweeked"
Rob
robnew.mjlj
(719 Bytes) Downloaded 2035 times
bobyspit
Post by bobyspit »
Engine Mfg: Triumph
Engine Code: FM
Cylinders: 4
Displacement (cc): 1390 (BORED OUT 1300)
Rev Limit: 5900
TPS or MAP: mAP
Boosted or Normally Aspirated: na TWIN DCOE AND ALSO NOW ON HS4'S RUNNING AAA NEEDLES
If Boosted- max Pressure (KPa):
Modifications: AS LISTEED
Chassis: STANDARD
Notes:
Matt306
Post by Matt306 »
I have acquired a pair of HS4 from a Spit 1500 thinking of replacing the HS2s what performance gain is there I havent done the work you have done.
Interested in the roller rockers option how did that work?
