Engine Mfg: Jake Raby-Aircooled Technology
Engine Code:AS41 case
Cylinders: 4
Displacement (cc): 2165
Rev Limit:6700
TPS or MAP: TPS
Boosted or Normally Aspirated:NA
If Boosted- max Pressure (KPa): --
Modifications: CR 9.8:1, Mahle pistons and cylinders, Counterweighted crank, H-beam rods, blueprinted and balanced internals, Webcam 86B, Headflow Masters 44 X 37mm valves w/double springs, Pauter 1.5:1 roller rockers, chromoly pushrods, port-matched intake and exhaust, dual Weber 44 IDF, exhaust 4-2 magnaflows-1 exit ceramic coat
Chassis: Vintage 550 Spyder replica(Porsche)
Notes: 172 hp, 144 ft. lbs. on engine dyno (w/dizzy)
VW type1 map-tps
VW type1 map-tps
- Mjconfig10.mjlj
- Updated part throttle AGAIN
- (706 Bytes) Downloaded 1870 times
Tle latest, there have been quite a few updates. This one has the compensation taken out, my wheel was 2 degrees off.
Some more part throttle changes to increase drivability and totally eliminate pinging.
- Mjconfig18.mjlj
- (695 Bytes) Downloaded 1520 times
Latest
Some very small mid and upper rpm/load changes.
- Mjconfig20.mjlj
- (695 Bytes) Downloaded 1261 times
