TPS to MAP conversion
Big Vern
Post by Big Vern »
What parts are required to convert my MJ v3 from TPS to MAP? :?
MartinM
Post by MartinM »
1 off MPX4250 MAP sensor (PS1)
1 off 270R resistor (R4)
2 off 100nF capacitors (C8, C9)
1 pc tubing
1 off bulkhead connector
3 off small cable ties
Component references are from http://www.autosportlabs.net/asl_dist/m ... v3_sch.png
I'd also (definitely) remove D7 and also remove R3 - and probably leave L1, C11 and C14 which are in the same TPS area of the board
You need:
1. Qty 1- Freescale MPX4250AP pressure sensor
2. Qty 2- 0.1uF ceramic capacitor X7R
3. Qty 1- 270 ohm resistor
4. Hose, bulkhead fitting, and zip-tie
We get this inquiry fairly infrequently, but thought it would be good to offer a conversion kit:
http://www.autosportlabs.com/mjlj-conversion-p-45.html
We'll add the equivalent TPS conversion kit shortly.
