megajolt junior v4 and coil on plug.
bad bug
Post by bad bug »
Brent will mjv4 be able to run coil o plug.
V4 has the same coil pack requirements as V3, since they both use the EDIS module.
ImpressIVe Power
Re: megajolt junior v4 and coil on plug.
Post by ImpressIVe Power »
bad bug wrote:Brent will mjv4 be able to run coil o plug.
Check this site for coil over plug on a 2002 model BMW using EDIS
http://www.hbci.com/~tskwiot/2002.html
Miguel
Patch1
Post by Patch1 »
Hi brent,
Is there any plans for MJL to drive the ford coil packs direct without the Edis moduel like MS can I think.
Also did anyone start to stock the connector + pins for the Edis 8 unit with you or us over here in the UK. I did find someone in America once, but you think I can find them now.
Mark
Hi Mark.
Yes. I will be laying out our more formal plans soon. However, if you browse the recent posts in "New Project Suggestions" you will get a feel for what's coming up.
