Will megajolt work with my oddfire crank v6 alongside the current injection system?
Cheers
John.
________
ARIZONA DISPENSARIES
Oddfire V6 turbo
jonnyboost
Oddfire V6 turbo
jonnyboost
Its a Alpine Renault PRV engine. Thats a shame if it wont be possible is there any alternative other than an engine swap!
John.
________
Xs850
John.
________
Xs850
we've thought about megajolting my dad's V6 alpine, the only way we can think of is to use 2 edis 6 units, and treat the engine as 2 3 cylinder engines, one edis for each bank. gets a single coil per plug too! the megajolt will receive the signal from one edis, and output the timing correction to both...
that's where the system may fall down, as the relative timings for the pip/saw signals to the second edis may not be in sinc. whether this is an issue we didn't find out, as we shelved the idea!
at least you are not alone with the prv v6!
Dave Pruit
I don't know if this will help but the early v6 buick engine were odd fire engines. These engine were fabricated from the existing v8s of the time, this was before the split throw crank. In any event these engines used the existing v8 ignitions systems with two of the distributor cap terminals blocked off. Depending on the degree of the firing order the same thing could be done with a edis 8 on a six cylinder motor, by not using one coil.
Edis 8 in a odd fire V6
IS it possible to be more specific on how to do the "job"
on using a edis8 on a oddfire engine, ia am very not into engines.
is it possible to use a Edis( modul into a 6 coil distrbutor?
