VR sensor calibration
anaphe
Post by anaphe »
Is there a way to fine tune the VR sensor calibration.
I inherited a car and the set-up is off by about 10 degrees. Car ran fine but I have degreed everything and the sensor is off by 1 tooth.
Thank you.
a
paulc
Post by paulc »
can you move the trigger wheel?
can you adjust the VR sensor?
I'm assuming you are asing if there is a configuration way to adjust for the incorrect install of the trigger wheel/VR.
