Peugeot Gti6 trigger wheel
boldy205
Post by boldy205 »
Hi, im new here, but have had a Mi16 powered Peugeot 205 on Megajolt and Webers for a while. I have now got a Gti6 engine and need to mount the trigger wheel on the crank pully, its not as straight forward as i thought it might be as its just a plain pully with one bolt (24mm spanner size) sunk in the middle of the pully. Has anyone here used the gti6 engine on Megajolt/used a similar pully and how have they mounted the trigger wheel?
Many thanks for any ideas
Matt.
Patriq
Post by Patriq »
I too had problems when I discovered that it wasn't as straightforward as I had hoped, to mount a trigger wheel on the crank on my engine. The profile of the crank made it virtually hopeless to mount a wheel to it.
I anyhow converted a dizzy to a 72-2 wheel, and it works nicely. Alexander here on the forum too has a converted dizzy with a much smaller wheel than mine. We use the same sensor though. The default Ford sensor couldn't read the teeth when they got small.
The upside of having the converted dizzy installation, is that I can adjust the trigger point for 10BTDC - as one would when adjusting a typical dizzy. Much easier than trying to adjust a wheel after it has been mounted to the crank.
I know that with the latest firmware/software, you can adjust the timing too. But you couldn't when I installed. And adjusting with the software cuts down on the range available for advance.
boldy205
Trigger wheel
Post by boldy205 »
Hi, thanks for the reply, sorry i didnt get back to you before. How do you meen converted a dizzy? and do you meen 60-2 rather than 72-2?
Any pictures would be very good
Many thanks
Matt
DannyP
Post by DannyP »
No, he means 72-2. The Ford EDIS MUST use a 36-1 pulley on the crankshaft. Or in the case of a distributor, a 72-2 since that is running at half the crankshaft speed.
Patriq
Post by Patriq »
Here's one thread on the topic,read from here and onward:
http://www.autosportlabs.org/viewtopic.php?p=7913#7913
