Extra wire
h4887
Extra wire
Post by h4887 »
The loom to my coil pack has a fourth wire (green/brown) which has a socket at the coil end. It appears to be original as it goes through the plug and socket between the coil and the Edis. It's evidently redundant now, but I wondered what it might have been for? I think the parts came from a Fiesta
Geoff
DannyP
Post by DannyP »
So it is an extra wire to a separate connector, or does your coilpack connector have 4 conductors on the plug?
h4887
Post by h4887 »
The coil pack connector has three wires. This one has its own female connector, about 3mm diameter.
Geoff
DannyP
Post by DannyP »
Sounds like it needs to be surgically removed then! Cut it out and insulate the cut, then you should be good to go.
