do i need tps or map ?
mikee
Post by mikee »
i ordered some bike carbs to fit my 1800 zetec, and asked if there would be a tps ..the guy said yes . when i received them there was no tps. He says i don't need tps or map...... is this right ???? if not i'll have to rig something up ,maybe off the throttle pedal...... any ideas ....--- mikee
The ability to adjust ignition advance based on engine load- measured by manifold pressure or throttle position - is an important part of realizing your engine's full potential, and to get the most out of your ignition system.
do the bike carbs have a spot for a TPS, but in your case it's missing?
On the subject of MAP or TPS: With multiple throttle bodies, A TPS is the simplest to connect, but using a MAP sensor is possible. See:
http://www.autosportlabs.net/MJLJ_V4_ve ... _.28TPS.29
MartinM
Post by MartinM »
What bike were they from?
R1 etc bike carbs should have a TPS fitted (or it might have been removed before sale I suppose).
Bike carbs, with a TPS, on a Zetec 1800 go very nicely!
I wouldn't bother with even thinking about a MAP setup - much too complex when the TPS route should be so easy
