Running map but also have a tps on my carbs so ?
darrenxr
Post by darrenxr »
Would it be possible my mjlj has tps compatibility?
If so would the 3 wire tps simply plug and play?
Since there is only one "load" axis, it must be either MAP or TPS.
However, it's possible to use the AUX input to receive input from the TPS- you can then use it to further adjust ("correct") your ignition advance, and/or trigger user outputs.
See the relevant sections in the installation / operation guide for more information.
Traditionally, the TPS uses a VRef signal so the voltage swings between 0 and 5V. By default, the AUX input is configured to read a resistive sensor, like a coolant temperature sensor that would be screwed into the head. I would imagine the TPS could be connected in such a way so as to provide a variable resistance based on throttle position.
I hope this gives you some ideas on how to progress further with your installation!
darrenxr
Post by darrenxr »
Ah excellent ok.... its just an idea to try and aid mapping.
Thanks brent.
