Which Ignition Timing makes more sense and why?
dr.occa
Post by dr.occa »
i'd like to gain a more definitive/substantive understanding of proper ignition timing based on the effects of mechanical and vacuum advance. there should be some fundamental "rule" governed by natural laws that can facilitate my accepting WHY timing should increase at high engine speed and low pressure and increase at high pressure and low engine speed or vice versa.
based on the 2 images of 2 different maps that i've included, could any of you help cultivate my understanding more thoroughly by answering my "WHY"s? thanks in "advance" (hardy har har) for your patience.
regards,
Dr.(not so "Doctorial") Occa
also, this particular website piqued my interest on the topic of ignition timing.
http://tw.myblog.yahoo.com/bighead-note ... d=726&sc=1
AUTOSPORTLABS
NonStop Tuning
www.86garage.com
"Poverty is not a virtue."
MartinM
Post by MartinM »
A quick Google on "ignition timing theory" brings up these two that seem to describe it well:
http://www.giant.net.au/users/wight/Ign ... ground.htm
http://www.giant.net.au/users/wight/Ign ... Timing.htm
...indeed your link (last row but one) describes why advance increases with rpm.
I would say that your second map is incorrect - the advance is increasing as load increases (%TPS increases or absolute MAP KPa increases) where as it should decrease.
To remember "which way up" a map is I always recall the phrase "vacuum advance" - when you have a vacuum (because the throttle closes and the engine has to suck against the throttle butterfly thus causing a vacuum), the ignition advances.
So more vacuum = less KPa = nearer the top rows of the map = more advance
alexander
Post by alexander »
and while we are idly on the subject, i just want to throw in a casual observation, from looking through a number of posted ignition maps, that most users here dont seem to have enough differential between high load advance, and low load.
this is just an opinion formed without a lot of investigation, but something to ponder for those who are looking more deeply into the construction of their map.
regards
alexander.
dr.occa
Post by dr.occa »
MartinM wrote:A quick Google on "ignition timing theory" brings up these two that seem to describe it well:
i appreciate the links Martin.
alexander wrote:...that most users here dont seem to have enough differential between high load advance, and low load.
could you elaborate more on what you mean? e.g. lack of definition in timing for both high & low load conditions?
currently, i'm running the below timing map which the car is very responsive using. my primary concern is the big "36 degrees" advance blanket i have covering the 3700 and above rpm range and through out the load spectrum in that same rpm band.
AUTOSPORTLABS
NonStop Tuning
www.86garage.com
dr.occa
Post by dr.occa »
this from a fellow Hachiroku.net member:
Twincharger wrote:Gas takes time to burn. That's the answer.
At low speed 10 degrees before tdc allows the flame front to travel from the plug and get a large portion of the air/fuel burning as the piston starts to go down.
If the engine spins faster, you need to start the flame burning earlier.
If you start too early, the piston has a hard time going up, and wastes power.
The flame front travels at different speeds depending on cylinder pressure, so intake runner length, exhaust header diameter + length, compression ratio, cam timing, overlap and duration all have an effect on cylinder pressure at specific RPM, so therefore affect optimum timing advance. The distance the flame front has to travel affects timing too, so a small bore engine is different than an oversquare, larger bore engine. So it can get very, very complicated.
Your maps look like base maps that haven't been fine-tuned to a specific car, but in general, low RPM likes 10-15 degrees, high RPM likes to start about 20 degrees before that. High cylinder pressure like when your cams are at their peak torque, headers and intake are resonating may require retarding timing a few degrees compared to off-resonance RPM. Also forced induction turbo, supercharged should remove about 1 degree of timing every 2 psi of boost, because the flame travels faster thru the highly compressed air/fuel mixture.
Just to throw a couple more variables in... The temperature of the air/fuel mixture can exceed the flash point of the fuel and make all the fuel ignite at once - detonate. You want to start the flame front burning before that happens. The octane of the fuel affects its flash point.
But, you were asking about mechanical and vacuum advance...
ok, imagine your nice ignition maps reduced to 4 cells. And a hypothetical distributor would work like this...
The mechanical advance (m) will advance the timing 30 degrees all at once around 3000 rpm.
The vacuum advance (v) will retard the timing 25 degrees at high manifold vacuum.
Imagine your distributor static timing set to 10 degrees
----------------------under 3000-------------------over 3000
throttle closed---- 10+v+m=10+25+0=35--- : --- 10+v+m=10+25+30=55
throttle open----- 10+v+m=10+0+0=10 --- : --- 10+v+m=10+0+30=40
It's much cruder, but pretty easy to adjust. The amount of vacuum advance is sometimes adjustable by a stop screw in the diaphragm, and the mechanical advance rpm can be adjusted by replacing some springs, and the amount of mechanical advance can be adjusted by filing some parts.
I'm sure there are many web pages on the subject that can explain it better than me...
AUTOSPORTLABS
NonStop Tuning
www.86garage.com
alexander
Post by alexander »
hi. the point of vacuum advance is to advance the ignition under lean (ie light load) running conditions. that is because the flame travels more slowly through the lean mixture, requiring ignition to occur earlier, so it (in theory) is completed by the same point in the cycle. my impression is that there is something in the vicinity of 10deg difference between full load and light load conditions (at any given engine speed) in an oem ignition curve. i (think) i have noticed that most maps loaded on this site have much less than that. if so, it is most likely causing less than optimal performance at light load (ie small part throttle), which in turn is likely to lead to less than maxiumum fuel economy at easy highway travel speeds. i am not adamant about that: it is just a general impression as it warrants some closer attention when setting up a map.
cheers
alexander.
DannyP
Post by DannyP »
Right Alexander. I have 5-8 degrees od advance built into part throttle, but it should probably be more(I had ten).
I had more originally, but dialed some out due to a plugged idle jet, which I know now.
Mileage could be more, with a little more part throttle advance it will be.
Mid to full throttle response is VERY good since I changed to the 'Jolt. Full throttle curve is very near the centrifugal distributor, but without the off-idle stumble that the 009 Bosch always has.
dr.occa
Post by dr.occa »
for with an AW11/4AGE, this was provided as a generous find by a fellow Club4AG member in response to my post:
AUTOSPORTLABS
NonStop Tuning
www.86garage.com
dr.occa
Post by dr.occa »
more jeremy ross awesomeness on the aw11 ignition tables thanks in part to jondee86 of Club4AG.com
AUTOSPORTLABS
NonStop Tuning
www.86garage.com
