Use my standard TPS?
Skytrax
Post by Skytrax »
Hello !
i have a golf mk2 8V turbo with a old Haltech F3 fuel System , I want to use Megajolt also to control the ignition.
Do I need two TPS?? or can I use the same TPS as my f3 without interference ?
Grateful for the response
Gilesy998
Post by Gilesy998 »
As long as your existing TPS uses a 5V reference, I don't think there'd be a problem, but on a Turbocharged motor you'd be better off using MAP sensing anyway as this would give you the facility to program in boost-retard.
Skytrax
Post by Skytrax »
Hello!
Okay, i see .. my F3 also has a MAP sens in the data box.
I am a little unsure if my TPS uses 5V
Thanks for the reply
