Initial timing table utility
Redbird
Post by Redbird »
I just finished assembling my unit and have started setting up my timing table. Not a lot of supercharged V8's running MJ at this time so I went looking for other ideas. I stumbled across this little utility on the megasquirt forums and figured it will help a good many get a baseline table to start with. Tweaking will still be required obviously but it should be a good point to start with. Now all I need to do is finish the engine, get it in the car,fab up a timing wheel for the beast, pray for no more snow.........
IgnitionTimingEstimator_Modded.xls
(47.5 KiB) Downloaded 706 times
