Tps load cursor
Lee James Hunter
Tps load cursor
Post by Lee James Hunter »
Just a silly question i cant find an answer to. I am running tps. My engine is not built yet & i am just bench testing. On a non running engine does the cursor not move up the ignition map table untill the engine is running. I am quite a experianced Megasquirter & on a stationary engine the cursor goes right up the table to wot. The tps gauge works correctly, is calabrated correctly & works fine with throttle opening. The cursor only moves to the first load bin at any throttle position. Are the ignition load bins in percentage or adc? If tps % do i set them 0-100%. Or do i have a problem?
Hello Lee,
Correct, you will see the cursor move when there is actual engine activity.
When the TPS is calibrated you can configure the load axis to represent 0-100% TPS.
