While I'm fighting to get the commapi that I belive now is only available in/for the J2EE (JDK)version, I've tried the mjljt_2.0.2 on my 2 WIN2K/J2RE machines. The program does not start, get the following error: Fatal exception occurred. Program will exit.
No problem with mjljt_1.0.0, the program starts but report the following errors when hitting GET CONFIG:
javax/comm/UnsupportedCommOperationException
java.lang.NoClassDefFoundError: javax/comm/UnsupportedCommOperationException
at org.megaJoltLiteJr.presentation.MegaJoltLiteJr.readConfiguration(MegaJoltLiteJr.java:565)
at org.megaJoltLiteJr.presentation.MegaJoltLiteJr.getConfigButtonActionPerformed(MegaJoltLiteJr.java:442)
at org.megaJoltLiteJr.presentation.MegaJoltLiteJr.access$200(MegaJoltLiteJr.java:20)
at org.megaJoltLiteJr.presentation.MegaJoltLiteJr$3.actionPerformed(MegaJoltLiteJr.java:309)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$ForwardActionEvents.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
I assume this is related to the infamous Commapi.
Brent what are you running?
mjljt2.0.2 error on WIN2K & J2RE 1.4.2
I think I know what your prob
I think I know what your problem is- Try putting the comm.jar in the same directory as the mjlj-2.0.2.jar file.
the 2.0.2 jar file will try to read the config right away, so that's probably why you're seeing the error right away.
Actually I just replicated your problem when I removed the comm.jar from that directory on my computer.
Let us know if that works for you-
Luca Lagonigro
Yes!!! placed the comm.jar fi
Yes!!! placed the comm.jar file in the same directory now 2.0.2 works on the office PC!
I've tried also on the Notebook on a fresh J2RE installation with no commapi.
MJLJ_2.0.2 reported: Unknown com port
After commapi files being copied in the right directories the message changed in a glorious: Could not commect to controller
No CLASSPATH thing done.
I found usefoul to create a .bat file that looks like this:
copy c:\commapi\win32com.dll c:\jdk1.4.2_04\bin
copy c:\commapi\comm.jar c:\jdk1.4.2_04\lib
copy c:\commapi\javax.comm.properties c:\jdk1.4.2_04\lib
I've the MJLJ at home I'll try again this evening.
Luca Lagonigro
Great!
I was editing my original post when you posted yours.
Thanks Brent!!!!
Thanks Brent!!!!
Luca Lagonigro
Yes!!!!
Mr. Runtime Display says: it's running.
Yes!! Yes!! Yes!!!
Yes!! Yes!! Yes!!!
Anders Wenblad
same prob
I can't connect .I moved all the files to the same dir.And
now I get in red letters (unable to open port com1;unknown serial
port)I know it's something simple that I'm not seeing.
Luca Lagonigro
There is still something wron
There is still something wrong with the commapi installation. Take your time, find the correct JAVA installation path on your hard drive and copy the 3 files in the correct directory:
COPY win32com.dll TO ..\java\J2RE1.4.2_x\bin
COPY comm.jar TO ..\java\J2RE1.4.2_x\bin AND IN YOUR MegaJoltTuning software folder!!
COPY javax.comm.properties TO ..\java\J2RE1.4.2_x\bin
You're done.
If you want to check where your Java installation folder is, you can run Java Web Start from the program louncher, then FILE > PREFERENCE > JAVA ... in the COMMAND tab you should see the base path.
I think it's better to start a new topic...
You're done.
