Is it possible to monitor IAT's with MJLJ?
BoostedE21
Post by BoostedE21 »
Hey guys,
I'm pulling together a turbo project, and I'm a bit concerned about my air intake temperatures. Is there a way to monitor those temperatures and retard timing accordingly automatically with MJLJ? Without the ability to change the timing when temps start do their unwanted climb, I can only run a pretty poor spark table to remain safe.
Basically need to find out if the MJLJ configuration allows me to wire in an IAT sensor, be it from GM or just a sender for a gage, and then use timing retard/IAT subsection. It's under the Spark header in megatune, IAT/Clt related ignition. I would rather just let the computer take care of altering timing based on IAT it instead of having 4 different files I run depending on outside temps, etc - and it would be a nice failsafe for my motor if my Meth/Water injection pump fails of if I accidently let the tank run dry. If MJLJ can't do it, would it be possible to buy a MS computer and have it just managing ignition for now? I'm not sure what the compatibility is between MJLJ and MS, and how much re-wiring would be necessary to switch between the two for just the ignition system.
Yes- you can accomplish this using the Auxiliary input of the MJLJ. The process comprises a few steps:
1. calibrate the aux input channel for your sensor. This involves scaling the raw "ADC" values to something useful, like degrees F or degrees C.
http://www.autosportlabs.net/MJLJ_V4_Op ... figuration
2. Edit the advance correction table to apply a correction factor based on the measured value on the aux input.
http://www.autosportlabs.net/MJLJ_V4_Op ... rrection_2
3. Wire up the sensor according to this guide:
http://www.autosportlabs.net/MJLJ_V4_ve ... iary_Input
Hope this helps, and let us know how your implementation works out.
BoostedE21
Thanks for the help! I should have mentioned, I have V3 not V4. Is it still capable of that?
Edit: A quick search indicated that it's not. Looks like it's time to upgrade!
Actually, our beta 3.3.x firmware adds this capability to the V3 controller, with some limitations. It will require hardware modifications, whereas it's built-in on the V4 controller.
http://www.autosportlabs.org/viewtopic.php?t=2100
