Toyota AE86 levin, 4age
Here is my complete setup. I have little problems but everything is solved accept jeting. I have little more air then fuel and in lower RPM is little unstable, but hope I solve that in couple days ahead. Hope you like it
- Senzor radilice 1.jpg (96.42 KiB) Viewed 27282 times
- Bobine.jpg (165.16 KiB) Viewed 27282 times
- Motor.jpg (107.13 KiB) Viewed 27282 times
Nice! Now few (bracket) tips in my native language:
Odlično izgleda, ali kao što brent reče moraš malo da izmeniš nosač senzora. Ovako će da vibrira i da ti pravi probleme. Vidi se da imaš okolo nekoliko šrafova, probaj to da iskoristiš.
Ja lično bih i bobinu nekako bolje učvrstio, recimo za karoseriju, tu negde gde je i sada, na pregradni zid između motora i kabine. Motor dosta vibrira.
Pozdrav iz Kragujevca,
Ivan
Ivan
'87 BMW 316 E30
1600cc M10B16
petrol + LPG, MJLJ
1600cc M10B16
petrol + LPG, MJLJ
Thanks, the sensor bracket is very strong its 4mm steel. When I sty and Idle and give trottle I watch on monitor and look how advance is progres. I dont see that advance has some stumbling. Also when I drive and pull full trottle nothing stumbling, go perfect, also when I pull slow trottle go perfect. Only when I am in some middle pulling thay start it stumbling at 3-4K RPM. I think that is something with fuel delivery and air fuel ratio but i will for shure try to fix Bracket with some other stronger bracket.
Thanks Ivan, the coil is fixed on chassis just you dont see on pics
Hvala druze, sve je fiksirano kako treba i bas tamo gde kazes samo sto ne vidis na slici a ovaj nosac radilice cemo pojacati sa jacim profilom. Pozzz
