getting a second hand megajolt v3 map
jpindy3
Post by jpindy3 »
hi all im new here,and also new to useing management.
i have hopfully got a megajolt v3 map,im planing to use this on my pinto,witch i am going to turbo useing a t3.
i have gone for the jolt as i am useing dellorto turbo carbs off a lotus,i will go to a squrt when i have the cash to sort some tbs out,as the std efi unit wont fit under the bonit of my mk indy.
my questons are
1.is the wireing the same as the megajolt jr,im going to use edis,i did find a good page that told you how to fit it,but is it the same for the v3?
2.is the map sensor built into the ecu,or do i need to get one?
3.where do i get maps from,and will i beable to do this at home?
thanks jamie
Hi Jamie,
Quick answers. The V3 Megajolt Lite Jr. does indeed use the EDIS module, and yes, if it's "MAP optioned' this means the MAP sensor is built in.
Be sure to review the V3 installation guide here:
http://www.autosportlabs.net/MJLJ_V3_ve ... tion_guide
Also see our operation guide for using the companion software- used to load Ignition Maps and for general tuning. A library of Maps can be downloaded from this forum.
http://www.autosportlabs.net/MJLJ_V3_Operation_Guide
Any other questions, we're here to help.
