help is there anyone here,bad backfire mj v3
jpindy3
Post by jpindy3 »
hi there i have a bad backfrie problem,all the leads are right as far as i know
plug leads 1-4 out off the left
2-3 out of the right
12 to 3 on coil
10 to 1 on coil
power to 8 to 2 on the coil the powers going through a 13 amp fuse i need to get a 15 amp
i have fitted the trigger wheel 9 tooth from the missing one and made sure that the sensor is in the middle of the 9th tooth,
help please
jpindy3
Post by jpindy3 »
anyone please
cng1
Post by cng1 »
Are all four cylinders firing and are all the headers nice and hot - if so that proves that the firing order is right.
With the laptop connected do you see RPM dropouts? If so have you checked your trigger wheel and sensor alignment? You should be aiming to keep any runout below 0.25mm for the sensor gap try aiming for a nice even gap of 0.75mm all the way round.
Hello Jamie,
For your initial testing, make sure the MJLJ is disconnected, as it is not needed for basic installation testing: The EDIS module will fire the engine at 10 degrees BTDC in "limp home" mode.
Trace back your trigger wheel / sensor alignment ensuring you've followed the step-by-step directions here:
http://www.autosportlabs.net/MJLJ_V4_ve ... stallation
Make sure your engine is at TDC for #1 when you are aligning the trigger wheel and sensor.
If you're still getting backfire problems, try swapping the 2 outer drive wires feeding the coil pack (10 and 12 from the EDIS module)- your coil pack wiring may be out of phase with your engine.
Let us know your progress!
Post by NITROPIXIE »
If your still struggling with this i can pop up to you and give you some help one evening in the week.
Offer is there, shouldn't take long to sort out
Make sure you have fresh fuel in the tank if it has been stood for a while
jpindy3
Post by jpindy3 »
i sorted it thanks lads,i had the btrigger wheel in the total wrong place,me just being blond,
