Can i run mega Suqirt and Mega jolt together
SupraFreak
Post by SupraFreak »
Hello everyone i am very new to the whole MS MJ thing. I have an engine that is DIS and a car the had a Disturb. engine in it so i want to do away with the old ECU and use something esle to spark the plugs and shot the injectors can anyone help me
PioneerX
Tach line
Post by PioneerX »
SuproFreak,
Yes it is possible to run both the MS & MJ together, just connect the tach line from the MJ to the MS to that it knows the currect RPM. This keeps them in sync.
There are variations of the MS that will do bot, but these are always a comprimse. The MS+EDIS is one such unit. This will do both injection & spark, but (as I have read) you lose the ability to control the high idle, as the control line is modded to run the EDIS instead.
