Reply to topic Page 1 of 1
Modify MAP V3 for aux input with TPS?
Post Modify MAP V3 for aux input with TPS?
As I am not using the TPS is it possible to modify it so that the aux input is using the TPS pin?
Seems simple enough to just wire it in where C12 or R3 is? I would need to cut the track going back to the processor?
I thought I had seen a mod similar to this (at least something soldered in to that area of the board) but cannot find it again?! (maybe I was dreaming)
James
Post
Yep seems like you have hit it on the head.
If you jumper from the aux on the board to the TPS R3 or C12 then you can use the TPS pin of the plug as the input for the AUX. There is no need to to cut the track to the processor as long as you place the jumper on the correct side of R3 or C12.
Just confirm you have continuity between the plug and the correct side of R3 or C12 to make sure that you are actually connecting to the correct side and not the processor side.
_________________
View user's profile Send private message Send e-mail MSN Messenger
Post
Oh yeah - I am being silly and not reading the schematic properly... looks like the correct side of R3 is perfect.
